Up to 20% off select tools
The Palm Zire m150 is a handheld, touchscreen PDA. It was manufactured by Palm in 2002. The the PDA has a 2 MB RAM and 2 MB installed memory.
Acceptable Battery Replacement on Amazon?
Hello :)
I recently got hold of a Palm Zire m150, but the battery is no good. I found a replacement battery on Amazon: (https://www.amazon.com/GAXI-Battery-Repl...). I would think that this is the right battery, but I am just making sure (for the safety of me and my Zire).
Thank you!
Add a comment
1 Answer
Chosen Solution
There should be nothing wrong with that battery - I've used CS batteries many times with no issues.
Just note that this battery requires soldering, and be prepared for that.
The seller is someone called "GAXIN" and they have a very short duration on Amazon and little feedback. Not sure if you can find some equivalent from a more reputable vendor. Not that I am saying anything bad against GAXIN, they may be a perfectly reputable vendor just getting their start. But until you know, or they've built a good reputation, you simply never know.
Score 2
Add a comment
Add your answer
_nec6678 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 30
All Time: 372
