Tecno's Spark 8 Pro was released on January 4 of 2022, and comes with a 6.6" display, and three lense camera configuration, and was made available in four colors.
Why is my phone freezing
Update (06/05/24)
Score 11
2 Comments
I Forgot my patten at safe folder
by
Why is my phone freezing?
by
Add a comment
Most Helpful Answer
Hi @albert32626
Try the following and check if doing either resolves the problem.
a). Wipe the cache partition and check if it works OK.
b). Restart and use the phone in safe mode and check.
To get into safe mode, tap and hold the Power button until the Power Off appears. Tap and hold Power Off until the reboot to safe mode option appears.
If it works OK when using it in safe mode then a downloaded app¹ may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and then test the phone in normal mode between each uninstall to see if it works OK or not. When it does the last downloaded app that was uninstalled was the culprit.
¹ A downloaded app is one that you downloaded and installed on the phone and didn't come preinstalled with the phone when you first got it.
Score 2
1 Comment:
There is many important files so what can I do?
by
Add a comment
To many apps downloaded and become full storage to become lag in gaming or apping
Add a comment
Try to update your phone to a newer version in the phone setting
Add a comment
I want my phone to work properly good
Update (10/20/24)
Good functioning phone is all i want
2 Comments:
Please repair my phone to function well
by
My phone it is slow ,how can I spread up internet network
by
Add a comment
Add your answer
Albert will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,295
