What to explain to customers
Hi everyone, my first post in here, and I hope some of you can help me out :)
I really need someone who knows iPhone / mobile repair to answer me on one question. I just started my own little repair business, and have learned screen replacement, battery replacement, camera etc. I`ve had customer who told me since the battery is not original from Apple (I am using high quality parts only)
They are scared the phone could be warm, could cause fire etc because of battery replacement? I dont want to be responsible for something like this, if the phone gets warm when changing the battery or whatever. What do I answer to the customers and what do I do in situations like this? Like I said, I am just using the best parts and doing battery replacement like every other mobile repair shop.
Thank you to everyone who wants to help!
Best regards
AK Mobile
Stavanger / Norway
1 Comment
That’s a very normal concern from customers, especially with all the stories online about damaged lithium batteries. The best thing you can do is be transparent and professional.
You can explain that high-quality aftermarket batteries from trusted suppliers are designed with the same safety protections as original batteries, including overcharge and temperature protection. A properly installed quality battery should not overheat or become dangerous under normal use.
It’s also good to tell customers that:
* Slight warmth during charging or heavy use is normal for all smartphones, even original Apple batteries.
* The biggest safety risk usually comes from damaged, swollen, or very cheap low-quality batteries — not from professional replacement with quality parts.
* You test the device after every repair to make sure everything works correctly.
To protect yourself and build trust:
* Use reputable suppliers only.
* Avoid ultra-cheap batteries.
* Check for swelling or damage before installation.
* Give custom
by David Warner
