The Black+Decker LM175 is an 18-inch 6.5-amp corded electric push lawn mower with a one-touch height adjustment, a polymer mowing deck, and a folding adjustable handle, designed for residential use. Model numbers include LM175 and 12411047.
How do I remove the blade
How do I remove the blade? LM1830
Add a comment
1 Answer
The hard part is stopping the blade from spinning while trying to loosen the bolt that holds the blade on. Try wedging a piece of a 2 X 4 between the blade and the housing. When reinstalling, use the same trick. (works to remove props on outboard motors too).
Add a comment
Add your answer
Brian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 233
