The next-generation 2007 Santa Fe debuted at the 2006 North American International Auto Show in Detroit.
Why the car is not starting?
I turn on the car. The engine try to start.car revs not moving and when I disconnect the battery and conect it again after 20 minutes the car start.
Add a comment
1 Answer
Hi 💫Gsnow💫, I hope your having a great day. Let's have a look on your problem, the question says that,[when you turn the key's over, your car does crank but does not start. But after you disconnect the battery and connect it again after 20 minutes, the car starts.]It seems that your car is experiencing a common issue where it cranks but won't start unless the battery is disconnected and reconnected. Following are some possible causes:
MOST RELEVANT CAUSES👇
  • Faulty Ignition switch:
* An electrical short circuit inside the ignition switch may cause the engine to fail to start.
  • Battery failure:
* Battery is a crucial component for starting a car, they provide power to the starter motor which then in turn starts the engine. Check the condition of the battery. BATTERY's ON AN AVERAGE LAST FOR ABOUT 4 YEARS, check when you bought it and then if its above 4 years, it might be just the time for the battery to get replaced.
* Electrical Issues:
* There can be many things under electrical issues, such as loose wires, corroded connectors, damaged fuses and worn wiring harnesses.
  • Car computer:
* Disconnecting and reconnecting the car battery reset's the car's computer alarm system, which might fix the "no start" issue of yours. Issues with the battery cable's connection can also prevent the car from starting, while a faulty car computer may be to blame.
  • OTHER POSSIBLE CAUSES👇
  • Fuel system problems:
* Fuel system problems include fuel line leaks, faulty valves, clogged filters, and bad gas tanks.
  • Compression: (probably not the problem)
  • It might happen that the compressor might not be in a good shape as they recompress after you remove the battery and put it again. It might happen that there is not enough compression in the ignition chamber.
That's all I can recommend as of my current knowledge based on internal combustion engine, I really hope this helps and I will see you later in the next issue. Feel free to ask any doubt or if anything goes wrong, I will always be there and I am sure I will help you out. Thank you Gsnow, ******have a 🌟Glorious day🌟
Add a comment
Add your answer
Gsnow will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 41
All Time: 491
