Up to 20% off select tools
Keyboard keys pressed automatically
Many keys are functioning automatically so currently using powertool application to disable the key, need a better solution
Score 1
Add a comment
1 Answer
Most Helpful Answer
It sounds like you might be experiencing a hardware issue with your keyboard. Before resorting to software solutions like the Powertool application, try cleaning your keyboard thoroughly to remove any debris or dust that might be causing the keys to stick. If the problem persists, you may need to consider replacing the keyboard altogether.
Score 1
Add a comment
Add your answer
Rejin Rajan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 235
