Repair and disassembly information for the Samsung Galaxy S21 5G Android smartphone, including model SM-G991U.
WI-FI constantly turning itself off
Okay so I got this phone second hand, it is the Galaxy S21 FE 5g, the wifi constantly turns itself off after about 10-15 minutes on the new ui 6 update, i’ve been through all settings involving samsungs smart connect, and factory reset multiple times. no cracks or outside damage. the bluetooth is fine so I know it’s wifi specific and happens on every network. it’s not my main phone but I would like to invest a little into fixing it, I just don’t know what i’d need to replace or if samsung is still as repairable as it used to be, i’ve had an iphone as my main for quite a while now
Add a comment
Most Helpful Answer
Check for any battery saver settings being turned on... it might be that it's turning off the wifi to conserve power.
Score 1
4 Comments:
Did you figure it out ? Mine is doing the same
by
I changed the power saving to high performance and it fixed the same issue I was having with the wifi turning off
by
I'm having the same issue
by
Same issue, and non of the solutions work.
by
Add a comment
Samsung has tech support for that. Not the sharpest knife in the world, but it is free and they can log onto your phone and look at it.
That is your best option.
Add a comment
Add your answer
dominick giovannelli will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 50
All Time: 1,554
