The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
Alternator not charging battery
I have installed new battery and alternator , new belt , replaced new battery cables negative and positive with new ends and cleaned and sanded all the grounds, only getting 12.48 volts at battery and alternator wires, Green/ orange wire from alternator to PCM 12.48 while running, could the PCM be at fault? There is no voltage drops either, tested with multi meter!
Add a comment
1 Answer
Most Helpful Answer
@derrick8834 have you scanned the OBD_II. If the PCM receives either under or over voltage, it will pop a code. Something like a P0562 or P0563
The amount of DC current produced by the generator is controlled by EVR circuitry contained within the PCM. This circuitry is connected in series with the generators second rotor field terminal and its ground. So yes, it is possible that this is strictly PCM related.
Since this is a new alternator, we are going by the assumption that the output voltage is proper. You may need this Charging System Besides checking all the wiring and the bulkhead connector, check fuse F22 in the power distribution center. There is also a fusible link in the wire (Black/White) from the alternator to the battery. See if that has continuity
Score 1
Add a comment
Add your answer
Derrick will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 23
All Time: 382
