Issues with sim card not being registered
Hi ive replaced the lcd on my device but after the sim card is not being detected at all any suggestions i have two different sim boards ive tried and i get the same results
probably a problem with the sim board connector flex cable / charging port check the connector
i hope u can get it to work
Same happened to me, I factory reset the phone, it recognised the SIM for about 1 hour then it stopped working again.
It almost look like a software issue, does anyone has a fix please?
P.S: I solved mine, you literally have 2 slots on the sim slot back to back make sure you put it in SIM 1.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 28
All Time: 442
