BeagleBone Black is a model of BeagleBoard introduced in 2013
Power light on then immediately off
Checking across most capacitors (like C2) reads almost shorted so I assume a component has failed. Short appears across the whole board so I assume a main power rail short and once the power regulator sees the short on the output it shuts down. Anyone have any guesses on which component(s) may have failed. I have 2 BBB with the same exact issue.
Add a comment
1 Answer
In my opinion, your BBB may have a broken power management chip or some shorted diodes. If all shorts disappeared after removing power chip, the power management chip must have a problem.
If not, other components(or both them and chip) have problems.
Add a comment
Add your answer
Techni Plex will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 22
All Time: 274
