Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
Gear changing is very tight
When i change the gear it is very hard . It take 2-3 attempts to change it
Score 2
1 Comment
Ghare change
by
Add a comment
1 Answer
Most Helpful Answer
@atif63383 I assume it's a manual transmission and you are having difficulties changing your gears while you are driving. If so, check you clutch first. After that you may have issues with your synchronizer, depends on if it is grinding the gears when you switch gears. Otherwise check your linkage to make sure things are properly routed.
For now, I'd suggest you look through this Swift Clutch And Transmission and see if you can narrow the issue down since it is a pretty broad topic
Score 1
Add a comment
Add your answer
Atif will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 66
All Time: 1,630
