Released in 2021, this lineup of the F15's features an Intel i5 or i7 processor, NVIDIA GeForce RTX GPU, and 15.6 inch 1080p display. These laptops have a sleek design and hardware optimized for performance-driven gaming at a lower price level.
Why is my computer making so much noise?
There is a lot of noise coming from my computer's fans. It's really too much. What could be the problem and how can I fix it?
Add a comment
Chosen Solution
@buesrakeklikci use this guide ASUS TUF Gaming F15 FX506L Back Cover Replacement to get into your ASUS TUF. For more details on the fan replacement, use something like this video Clean all the air inlets and cleaning the fans might help but my experience is that it is better to replace them once they become noisey. Worn bearings etc. will lead to prematurely failure and could cause major damage.
At this point you are better off replacing the thermal paste as well. that way you will only have to work once on all of this. Use the generic iFixit guide How to Apply Thermal Paste for that.
Since iFixit does not yet have a guide for the fans etc, and while you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Electronics Skills Image
Guide
Difficulty:
Moderate
5 - 20 minutes
ASUS TUF Gaming F15 FX506L Back Cover Image
Guide
Difficulty:
Moderate
10 - 20 minutes
Score 3
Add a comment
Hi this is an overworked fan, try to
  1. clean the fans themselves
  2. don't use it on a bed or other, use it on a hard surface
  3. Swap out the fans
  4. See if the connector for the cpu is properly attached and the thermal paste is properly applied
Add a comment
Add your answer
Büşra Keklikçi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 533
