Steering and electric problems
The steering is so heavy and the camera is not working what cause this problem car tucson 2013 limited edition
Greetings Otaku,
Have you checked the fluid level for the power steering fluid? Is the belt slipping or missing from the power steering pump? In addition to this a sudden heavy steering issue is a symptom of a failing or failed lower ball joint.
The camera I would start by checking fuses, wire harness specifically where the camera goes into the back trunk and connections.
Cheers!
Monte
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 429
