Why is it not charging?
When ever I plug in my superlight to charge it and take the charger out after a while it shows a red light and turns off a couple seconds later
I have the same problem but when I plug the charger led is off. My mouse is off I can’t use it , already change the cable but do not match.. can you help me please? 🙏
This is usually one of two things,
The charge port, this can easily be ruled out by being able to use the mouse wired.
The battery, it may have degraded for various reasons however if the mouse indicates its charging when plugged in and when unplugged it dies, its most likely the battery is no longer able to hold a charge.
What about if when I plug in my GPRO Superlight to charge and it doesn't charge. Like the light on the top won't turn on.
And when i try to plug it into the cord/wire the mouse still won't work.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 59
All Time: 5,383
