Up to 20% off select tools
The Galaxy Watch Active2 is a smartwatch from Samsung Electronics. Its model number is SM-R825, SM-R830, or SM-R835 and was released in August 2019. Repair your Samsung Galaxy Watch Active2 with these guides.
My watch screen opened up
I went swimming and i put the watch next to the pool but it fell into the pool, the screen popped out and when i let it dry it still doesnt turn on what can i do to fix it or is it gone forever?
Score 1
Add a comment
1 Answer
Chosen Solution
Depending on how it "opened up". If the screen separated completely with the watch I suggest you replace the watch completely. But even so if it slightly opened and water entered the system repairing would be of no use
Hope it helps
2 Comments:
It opened up but still attached with little droplets of water which i managed 2 remove
by Share
Try charging it (make sure it is dry) if it turns on you are good to go(if the screen can easily stay there with no movement). If it is still not sticking back , I suggest opening it up, gently apply heat to the screen to make the adhesive sticky and try putting it back. If it doesn't work I suggest you get some of that adhesive (when I get the name I will inform you) and try putting it on.
by Share
Add a comment
Add your answer
I5m4il7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 791
