A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
Adhesive remover in screen
please help my the adheasive remover got in my screen and it is squelching around i can see the liquid moving what do i do to get it out
Score 1
Add a comment
1 Answer
Most Helpful Answer
I'm not sure what adhesive remover you used, but if it is alcohol or water based, it should evaporate over time. However, it may leave some traces behind. I would start by turning the laptop off and disconnecting the battery (if possible) and letting things dry. Opening the display assembly is very difficult on these models so this may be your only option.
Try to leave the laptop somewhere warm and dry to speed up the evaporation, and cross your fingers that the display isn't damaged.
Score 1
Add a comment
Add your answer
User: Failure will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 18
All Time: 263
