Up to 20% off select tools
Repair and troubleshooting information for the Lenovo IdeaPad 5 15IIL05. Lenovo's Intel-based IdeaPad 5 laptop was released in 2020. Includes device identification details, technical specifications, and common issues such as hinge and power button problems.
Hinge Broke LCD Display
My laptop is about 3 or so years old and has been dropped a few times, however it wasn't until recently that the back right hinge broke off from the LCD Back Cover breaking some of the plastic off with it. I am trying to figure out what I am needing to buy in order to repair it. Any idea what I am needing?
Score 5
Add a comment
@andrewboot16282 most likely the ninges since they got stuck, unless you get them to move smoothly again. Soak those in some WD 40 and continue to work them until they are no longer sticking. Lubricate them after they are clean and dry with some 3-in-1 oil and work it into the hinges by opening and closing those a couple of times. If the hinges are bend or otherwise damaged, you will have to replace those.
Next parts to replace would be the middle frame where the hinges screw into and the LCD cover. Now, we do not know the condition of the top case, that is the part where the keyboard sites in etc. That you will have to evaluate as you open your computer.
To work on your Lenovo use the Lenovo IdeaPad 5 15IIL05 Hardware Maintenance Manual
Add a comment
My laptop hinge broke twice and this is the third time. The screen was not damaged. Can this be fixed?
1 Comment:
@marialopez49572 possibly but we need to know more about it. Make and model is a good start. How did you fix it the first two times?
by Share
Add a comment
Add your answer
Andrew Booth will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 73
All Time: 1,918
