Up to 20% off select tools
Machine has error code 245?
Aquasmart washing machine is coming up with error code 245 ? Please explain this, thanks
1 Comment:
Hi @janet16013,
What is the model number of the washer?
Just verifying that the status light error code sequence on the washer is
1 1 1 1 0 1 0 1 as viewed from L→R . 1 = light on, 0 = light off?
by Share
Add a comment
1 Answer
Have you removed the inner bowl and check under pump cover ,if so have youput the cover on around th correct way.Is the flapper inside housing of pump obstructed.
Add a comment
Add your answer
Janet will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 491
