Up to 20% off select tools
Also known as the FZ6 Fazer, the FZ6 was produced between 2004-2009 for model years 2005 through 2010.
Right indicator not working
Left working right indicator not working
Score 2
Add a comment
Most Helpful Answer
@ranadebnath you are not telling us what you have already checked. Since the left side works, your blinker relay and fuse are likely fine. Most common issues for a not working indicator are a burnt-out bulb, a faulty switch, or a loose/pinched wire.
Not sure why you would need to "Replace the voltage regulator rectifier" which really sounds more like a guess to me ;-). Anyhow, you can now download the SM for the FZ6 from this page Yamaha FZ6 under the Documents Header. Page 402 shows you the diagram for the signaling system.
Score 1
Add a comment
Add a comment
Add your answer
RANA DEBNATH will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 54
All Time: 895
