A guitar shaped controller for Guitar Hero III of the Guitar Hero video game franchise.
Green + red + yellow cause strum
Hi, having an issue where pressing the first three frets at once causes a downstrum. When I hold these frets, I can still strum up after the first downstrum has happened, but strumming down has no effect.
I have already resoldered the neck connector pins and have even gone as far as to completely unsolder the entire 14-pin strum bar connector from the "main" board, the one with the Xbox button. As far as I can tell, none of the connections on that 14-pin board are shorted to the one next to it and I've run out of ideas.
What could I do next to try and pinpoint the problem? Has anyone fixed an issue like this on their controller?
1 Comment
Issue actually fixed here: https://www.reddit.com/r/GuitarHero/comm...
OP here soldered signal diodes between certain connections to resolve the issue.
What I posted before did not work.
by
Add a comment
Chosen Solution
Add a comment
Ended up still being an issue with the neck connections being wired incorrectly. According to Reddit user DeBlakee, the guitar uses a 4 x 4 matrix for inputs, which explains how the neck can affect the strum bar. Link to the Reddit comment here.
Add a comment
Add your answer
Martin V will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 37
All Time: 346
