Repair guides, disassembly, and troubleshooting information for the HP EliteBook 845 G8, an AMD business laptop released by HP in December of 2020. Identified by model number 1W3K7AV.
Can we have a general cleaning guide?
I just visited India. There is SO much dust there like I can't even describe it. I noticed more overheating so I assume it's dust filled into fans and stuff. Even the screen is icky. I was hoping for a cleaning guide (ex; fans, screen, between the bezels)
1 Comment
I guess....the answer is not necessary for being detailed. Anyone can do it.
All you need is a strong vacuum that can spin the fan. As for the bezel you, use it with great caution and avoid touching the screen.
by
Add a comment
1 Answer
Most Helpful Answer
Hi @kalyabhatt
Here's the maintenance and service guide taken from this support webpage for the laptop.
It details the necessary steps to completely disassemble the laptop if that's what you want to do.
Score 2
1 Comment:
Generally the parts that need maintenance are the fans, which can collect dust (plus anywhere else where dust has entered the laptop), and the thermal paste, which is on top of the CPU and under the heat sink.
So, basically use the pre-existing OEM guides on iFixit for the following:
* fan: HP EliteBook 845 G8 Fan Replacement
* and heat sink: HP EliteBook 845 G8 Heat Sink Replacement
If you've watched Andy's dust cleaning videos from the Salem Techspert YouTube channel, then you've already have a good idea on how to clean dust from this laptop.
by
Add a comment
Add your answer
Kalya Bhatt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 388
