The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
How do you remove lower steering column cover
The ignition key is stuck in the ignition. I've tried the key release with no luck. I need to remove lower steering column cover to see what's going on. How do you remove the lower cover?
Add a comment
1 Answer
There is a key removal bypass underneath the keyhole to remove the key when this happens. I pulled up a video for you that shows you how to use it to remove the key.
https://www.youtube.com/watch?v=UNVbCakt...
Hope this helps!!
Cheers
Monte
Add a comment
Add your answer
Dane Justice will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 484
