The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
The Disc could not be read.
Red Error Message: The Disc could not be read. Please read the Nintendo Gamecube instruction book for more information.
Add a comment
1 Answer
@johnllovesr try and see if it reads an audio disk as well as different game disk then the one you were trying. Sometimes a disk can cause this error.
It is possible that this is either a dirty laser or a failing laser. First try one of those commercially available CD cleaner kits. Run that a couple of times. If that does not work you could could try to increase the power to your laser. Follow this guide. Just be moderate, you do not want to burn it out. The other thing to try would be a recalibration of the lens. For that follow this guide. After that I'd suggest that you replace either the lens or the optical drive. Nintendo GameCube Optical Laser Lens Replacement Nintendo GameCube Optical Drive Assembly Replacement
Nintendo GameCube Optical Laser Lens Image
Guide
Difficulty:
Moderate
30 - 45 minutes
Nintendo GameCube Image
Guide
Optical Laser Lens Power Adjustment
Difficulty:
Moderate
30 minutes
Nintendo GameCube Optical Drive Assembly Image
Guide
Difficulty:
Moderate
30 minutes
Guide
Nintendo GameCube Lens Recalibration
Difficulty:
Moderate
20 - 25 minutes
Add a comment
Add your answer
John L Love Sr will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 40
All Time: 680
