The VW T5 was produced from 2003-2015 and then replaced by the T6.
My aircond work intermittently.
When I switched on, the aircond may or may not working. But when working, the aircond is strong enough to cool down the whole car during a hot day. So, I'm not convinced if the problem is the compressor. Must be something that related to sensor or ambience temperature before go to the compressor.
1 Comment
After throughly checking the aircond system, we found that the air quality sensor is fault. The sensor is sensitive enough and give a report to ecu on how the surrounding air quality and the ecu may shut the compressor as necessary. So hopefully this is the culprit. I'm still waiting for the parts to come and update the situation.
by
Add a comment
Chosen Solution
Öncelikle klima devreye girdiğinde fanları kontrol edin fanların ikiside çalışıyor mu eğer ki çalışıyor sa peteklerin temiz olduğunu kontrol edin petekler temiz değilse petekleri temizleyin T5’lerde klima sorunu kayış kaydırıyor olabilir bunun için en son çare bir klima ustasının bunu kontrol etmesi olacaktır
Add a comment
Add a comment
Add your answer
Wisnu Waloejo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 22
All Time: 874
