Up to 20% off select tools
The Dell Latitude Series is designed mainly for professional use. This model is a 14" laptop released by Dell in 2018. The Dell Latitude 5490 emphasizes durability, portability, security, and is known for its long-life cycle.
Why it became hang
my pc become slower than before it hang alot
Score 1
Add a comment
1 Answer
If your computer has been freezing/hanging a lot, there could be several causes. You may want to start with checking on how much space is left on your drives. If any of your drives are almost full, this can cause slower, worse performance, which can be solved by clearing some space on the drive. Before deleting files to free space, check to see if you have a second slot for an additional SSD (Solid State Drive). This will add more space.
Another reason could be due to a hard drive. These are mechanical, so they perform slower than modern SSDs. If you still have a mechanical hard drive, I recommend replacing it with an SSD.
Hope this answer helps your freezing/hanging problem. :)
Add a comment
Add your answer
asmaa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 250
