Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
Destroyed Heat Dissipation Stickers
In order to remove the three display cable connectors, I completely destroyed the three pieces of extremely thin, black, heat dissipation (hd) stickers that covered each of the connections. I saw that ifixit carries a replacement hd sticker kit for the Series 6 44mm watch only. It’s out of stock so I can’t even try to adapt it for my Series 5. Is it absolutely necessary to replace the hd stickers? Is there an acceptable alternative hd sticker here on ifixit or on the internet I could use? Thanks!
Add a comment
1 Answer
The tape is EMI shielding not heat. Finding the die-cut part is very hard.
The solution is to patch up what you have. I use this tape to patch things up Conductive Copper Tape 100% Pure Double Sided Adhesive Copper Foil Tape for Stained Glass, Guitars, EMI Shielding, Electric Connections, Repairs, Grounding, Crafts (1inch x 66FT)
Add a comment
Add your answer
Happy Dad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 320
