A 32" Roku TV released by TCL in 2018.
TV twitching and double image
My TCL 65” tv starts twitching and double image after a few minutes of warming up. I replaced the t-con board but no improvement. Any suggestions what else can I do?
Score 4
2 Comments
Mi televisor tiene la mitad que no se ve y a veces si como puedo solucionar ese detalle
by
@juancarlos72447 that could be a bad buffer board. Check the ribbon cables first to make sure there is no rip, corrosion or etc. that may cause this. If those look ok I would suggest you try a tape-off.
by
Add a comment
Most Helpful Answer
@jacs46856 since you already replaced the T-con board which would be the primary suspect, the next are your LCD driver boards. Those are the boards that the ribbon cables from the T-con board connect to. In your TV's case there might be two of those (some may have four) but we would need to see those. Power your TV off, disconnect the power cable. Then remove the ribbon cable from one driver board. Plug your TV back in and try it. One half of the screen will not worki but let us know about the one that shows. Let us know if there is any change. Next try the same thing with the other side.
Score 1
Add a comment
No meu caso só possui uma fita não duas, como proceder?
Score 1
Add a comment
Add your answer
JACS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 63
All Time: 1,456
