Up to 20% off select tools
The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
Fixing my power button
Why is my power button isn't working
Score 8
Add a comment
Most Helpful Answer
Although it's hard to be sure just having your question to go on, the first thing to do is make sure it's not a software problem. The best way to do that would be to restore the phone to factory settings (note that you will lose all of your data and pictures), or you can try starting the phone in safe mode. Here's Verizon's instructions for putting your phone in safe mode.
If the power button is still misbehaving, then you most likely will have to replace it. I didn't find any step by step iFixit-style guides for your exact phone, but I did locate on for the A12 Nacho, which is a slightly newer version of yours, but as far as I can tell the replacement procedure for the power button is the same on both.
Manuals / Samsung Galaxy A12 Nacho / Fingerprint sensor and power button - Nobody Calls Me Chicken
There's a video that does match your phone exactly that might be worthwhile for you to view, as it talks about fixing the button that's not working right; as far as I can tell the button basically fell off it's mount and just needed to be remounted in order to work.
how to repair Samsung Galaxy A12 power on button #SamsunggalaxyA12 100%easy idq1009.official - YouTube
Hopefully at least one of the things I've mentioned will help you get your power button going again.
Score 1
2 Comments:
My phone is off thats the problem. I cannot access it
by Share
https://youtu.be/SQ6ah1ypZWM
The link above should turn it on
by Share
Add a comment
well, when you drop your phone, the power button will probably stop working
what i did is i went to settings, then i enabled double tap to switch it on
it should work
if your pone dies and the power button isn't working, just search "how to power on phone without power button" and it should work
I hope thes helps
Add a comment
Phone fell in water but only the power button stopped working
Add a comment
My is too much off and on please and please help me it
Add a comment
Add your answer
Meqsood Hashim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 99
All Time: 4,276
