Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
GPU Heatsink temperature does not appear
Guys, is there any way to read the GPU Nvidia 9400m or GPU Diode temperature on the iMac? From what I remember, I could only see the temperature in the High Sierra.
4 Comments:
Are you using the latest versions of TG Pro?
by
@danj Yes, 2.89. From what I remember, I was never able to see the GPU temperature when installing a system above high sierra, using a patch.
In High Sierra I can see the temperature, but in Catalina onwards I can't.
by
@danj At the time of Catalina it was the Catalina Patcher Dosdude1, and currently OpenCore Legacy Patcher, but if I install the official High Sierra I can see the temperature.
by
Add a comment
1 Answer
Well… I think you found a weakness in the shim service as TG Pro (or likely any temp monitoring app) can’t gain access to the needed firmware API call.
I hit that too with a few custom Apps with OpenCore. Sadly I ended up rolling back to the highest Apple supported macOS my system could use.
Add a comment
Add your answer
Ramon Ferreira will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 292
