The Mi 11 is a flagship smartphone by Xiaomi with a 6.81" quad-curved AMOLED display, a 108 MP main camera, an in-display fingerprint sensor, and a 4600 mAh battery. It’s the first phone to feature the Qualcomm Snapdragon 888 and runs MIUI 12 over Android 11.
Touch screen not working after battery replacement
Hello.
Today i changed the battery on my Mi11 for the second time ( the first that i bought somewhere else was not good). Everything went perfectly fine the first time.
Today, after installing the 3rd battery, when i reassembled the phone, the touch screen was not working. I disassembled again and noticed that the touch screen started working again as soon as i loosened the screws on the right side of the motherboard cover.
I was able to replicate this a few times ( screen functioning without the cover screwed, and not when it was correctly screwed).
I then decided to re disassemble everything and start over to be sure... but now the touch screen doesnt work anymore, I am not sure which main connection is responsible for the touch screen, but I checked every cable and couldn't find an issue or any damage.
Any help is appreciated.
Thanks in Advance
Add a comment
1 Answer
Your phone uses a single connector on the display itself, unlike other phones such as the iPhone where there are separate flex cables for the display and the digitizer. So all the signals for the touch screen run through that one connector, shown here.
Of course, that connector plugs into the daughter card, not the motherboard, so there are more connectors and cables in the path; you have to get those signals from one to the other after they come in from the display. There are two cables and there's no sure way to tell which one those signals travel on, but I'd suggest starting with the one right next to the display connector here.
And here's the other end of that cable.
I suspect the other cable is probably not what you're looking for, but have no way to be sure, so you might end up having to replace that one as well. Here's the other one.
Assuming you can't find anything wrong with the connectors, I'd suggest you start replacing parts. The daughter card is the first one in the path; that receives the display signals and passes them along, so any damage internally or to any of the connectors could cause it to fail.
In addition, those two interconnect cables, labeled as left and right in the guide, are likewise susceptible to damage and could be the source of the problem, so replacing them is another possible fix.
So I'd suggest replacing those three parts and seeing if that gets your touch screen working again. Of course, it's always possible you've got a defective replacement screen, so if possible you should try the original screen and see if the touch still works with it; if so, you should consider that your new screen might be bad.
1 Comment:
Thank you for the very detailed answer. I didn't touch anything on the daughter board, and only replaced the battery ( the screen is the original one )
Do you still think one of the best fix would be replacing this daughterboard ? I had the feeling something was wrong around the mother board connector since it was working on and off when mounting the MB cover.
by
Add a comment
Add your answer
Jackal will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 49
All Time: 641
