Up to 20% off select tools
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
electrical problems with my Dodge
brake light and signal only work on passenger side but i changed fuses and sockets checked for wiring
Add a comment
1 Answer
Most Helpful Answer
Hi @patrickmck82734
Check if there's a good earth connection for the rear driver side lights.
If the earth is OK use a voltmeter or a test lamp and check that the power is getting to the lights.
Here are some images from the 2002 Dodge Ram repair manual, showing the harness cable run and the connector pin out for the rear lights that may help.
(click on images)
Score 1
Add a comment
Add your answer
patrick_mckenna3@icloud.com will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 398
