Screen coming loose from keyboard
Hi! So excited to be using this site for the first time. The lower right corner of my screen is coming loose from the upper right base of my HP laptop. I can see a wire from the screen to the base. On the base, I can see the top part lifted from base. This has slowly gotten worse over time to now I don’t close the laptop anymore. Thank you!
6 Comments
Hi @ilav,
What is the model number of the laptop?
by
Hi @jayeff! I am away from my PC today and will provide tomorrow. Thank you!
by
Hi Ila, please provide a picture so I can see how your computer looks like, with the picture, please send me the model of your computer. Thanks.
Sincerely,
San.
by
@jayeff HP Laptop - 17-by3065st
by
@sanchittiwari HP Laptop - 17-by3065st
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
Hi @ilav
Here's the maintenance and service guide, taken from this support webpage for the laptop.
Go to p.65 to view the procedure to remove the display assembly.
This will allow you to check if the hinges are screwed securely to the base enclosure and also the lid.
If the hinges are damaged and need replacing, their part number is Item #4 on p.22. Search online using the part number only, to find suppliers that suit you best.
Note: You can't add images to a Comment, only to your question or to an answer. Here's how to do it in ifixit Adding images to an existing question
3 Comments:
@jayeff Thanks for the detailed response. I reviewed the maintenance and service guide which is very helpful. I am terrified to give this a try for many reasons (like why do I have to remove the optical disc?) but will give it a go. Accepting your answer after I post this comment.
by
@ilav
You have to remove the optical disc i.e. dvd drive so that you can remove the base cover as some screws are hidden by the drive when it is in position
The dvd drive is a sealed unit so it's not a problem unless you drop it on the floor ;-)
Good luck. It's not as hard as you think. Just make sure that you follow the procedure especially about removing the battery as you don't want any problems happening with the battery connected to the motherboard when using tools inside the laptop
by
Hi. I had the same issue about a year ago, probably since the time this comment was posted. But I kept using it with a bit more care, But it popped off a screw at a given moment out of nowhere. I havnt been brave enough to mess with it because I dont know what Im gonna find and if im gonna be able to put it back together. But the answer sounds good enough, maybe I'll give it a try. Thank you
by
Add a comment
Add your answer
Ila V will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 28
All Time: 862
