The Asus Tuf Gaming FX505GT Is A 15.6 Inch Laptop With A Intel Core i5 9300H And A GeForce GTX 1650. It has Windows 10 and was made by Asus in 2018.
No link lights on LAN port
I have an Asus fx505gt gaming laptop where the onboard LAN does not connect or show any link lights. I can plug the Ethernet cable into any other computer, even into a USB Ethernet adapter on the same laptop and it works fine. The NIC shows in Device manager and has current drivers. The next steps I need to take are to check for any bent pins and to update the BIOS.
According to pictures I've seen it looks like the LAN is soldered directly onto the main board and isn't a replaceable module. Does anyone have any advice to repair the onboard LAN, or if it is even possible? The USB 3 Ethernet adapter I am using works most of the time, but often struggles in high bandwidth situations.
Add a comment
1 Answer
Most Helpful Answer
Hi @mrbryce2000518
I realize that you said that you checked the LAN adapter in Device Manager and it was installed OK but did you check if the Power Management setting of "Allow the computer to turn off this device to save power" has been enabled?
If not, uncheck the setting if it is checked, click OK to save the changes, restart the laptop in the normal manner and check if it now works OK
Go to Device Manager → Network Adapters → right click LAN adapter entry → Properties → Power Management and check the status of the setting
Score 1
1 Comment:
Thanks, I will check this when I can. In my experience, I would still see link lights even if power management was enabled, but that was often with Intel or Broadcom adapters, not Realtek.
by
Add a comment
Add your answer
mrbryce2000 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 29
All Time: 375
