Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
My phone speaker is not working
my phone speaker not working
Score 19
13 Comments
My phone battery is not charging
by
My phone blinks
by
by
My phone speaker not working
by
My mobile does not work
by
Show 8 more comments
Add a comment
Most Helpful Answer
There are a few things you can try first:
  • Restart your phone. This is often the simplest way to fix minor problems.
  • Check your volume settings. Make sure that your phone's volume is turned up and that you're not in silent mode.
  • Clean the speaker grills. The speaker grills on your phone can get clogged with dirt and dust, which can block the sound. Use a soft brush or cloth to gently clean the speaker grills.
  • Update your phone's software.Sometimes, software updates can fix bugs that cause problems with the speakers.
Score 6
3 Comments:
It's helpful
by
One speker not work
by
Not fixed by these suggestions. I destroyed by pin
by
Add a comment
Here are some quick fixes for a non-working phone speaker:
  • Check the volume: Make sure your phone isn't muted and the volume is turned up.
  • Restart your phone: A simple restart can often resolve software glitches.
  • Clean the speaker grille: Dust or debris can block the speaker. Use a soft brush to clean it gently.
  • Test with different audio sources: Try playing music, videos, or making a call to see if the issue persists across all apps.
If these don't work, the problem might be more serious and require professional repair.
Score 2
2 Comments:
Tecno spark 6 mobile speaker is not working in my mobile
by
My phone is HONOR 90 I destroyed it since I couldn't locate the Sim slot. I inserted the Pin to uplift the Sim case unfortunately I destroyed the speaker
by
Add a comment
Well check out the following: https://www.youtube.com/watch?v=vAG8B0Dx...
Score 2
Add a comment
Hello guys,
my phone doesn't vibrate, how can i solve that issue please.
TECNO CAMON15 premier.
1 Comment:
Well Checkout the following video it might help you in fixing the issue:https://www.youtube.com/watch?v=W0-_BKzz...
by
Add a comment
Check volume levels
Reboot your device
Adjust the app sound settings
Clear the speaker
Add a comment
No improvement
Add a comment
My phon spiker is not working
Add a comment
How do I fix my speaker
Add a comment
Add your answer
asfaw kefyalew will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 55
All Time: 4,350
