Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
Sound and tight during door open
Sound and tightness during door open
Add a comment
1 Answer
Most Helpful Answer
Hi @saravanan45237
What is the sound like? Also which door, freezer door or refrigerator door, you didn't specify?
Post a video where the noise can be heard as the door is seen being opened and closed, in your question. Here's how to do this in ifixit Adding images to an existing question Note: posting a video is the same procedure as posting an image.
In the meantime, if your model is an RM-3862, check if the door gasket is OK i.e. not broken, loose, warped etc or perhaps the door hinge (top or bottom hinge) is causing the noise and the door to not function correctly.
With the door gasket, check all around the problem door, especially on the underside where the gasket is less noticeable.
If it is the door gasket, search online for 3108704.382 to find suppliers that suit you best.
If it is a hinge, search online for 3850386016 to find suppliers that suit you best.
Here's the gasket kit installation guide and the parts list that may help
Score 1
Add a comment
Add your answer
Saravanan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 442
