Up to 20% off select tools
Repair and disassembly guides for the Compaq Presario CQ40.
The system clock gets reset.
Whenever I shut down my laptop, the system clock gets reset. What could be the reason and please suggest the solution.
1 Comment
revisa la batería que está al lado del disco duro que viene conectado a la placa, lo mas seguro es que este mala por eso es que se reinicia por eso tienes atrasada fecha y hora.
by Share
Add a comment
1 Answer
Chosen Solution
Hi @amitgandhi95125
The coin cell RTC battery (Real Time Clock) connected to the motherboard has failed and needs to be replaced.
This battery maintains the time and date and all the BIOS settings when the laptop is turned off. It is a non rechargeable Lithium coin cell battery and usually lasts for 4-5 years
Here's the maintenance and service guide for the laptop.
Go to p.50 to view the procedure to remove/replace the RTC battery
Search online for 486835-001 to find battery suppliers that suit you best.
Score 3
Add a comment
Add your answer
Amit Gandhi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 325
