Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
Very dark screen when playing games
I’ve just purchased a second hand game boy advance and it’s quite hard to see the game due to dark screen. I’ve tried the usual holding select and clicking left/right but no good. Also found the pot behind the serial number but no good unless I need a very small screwdriver but not sure. Any help greatly appreciated
Add a comment
1 Answer
Most Helpful Answer
The Game Boy Advance doesn't use a backlight, which can make it hard to see the screen in low-light conditions. If you are willing to take apart the GBA and use some tools, there many backlight modifications on the web that can be used to help install a backlight into your GBA. But you must keep note: by installing a backlight mod into the GBA, you must do it correctly, as you could cause damage to your GBA if done incorrectly. You will need some tools, and a soldering iron, for the task.
Score 2
Add a comment
Add your answer
Lee Wheller will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 68
All Time: 2,609
