Up to 20% off select tools
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
Panic-Full-restart randomly
Hello, i have an iphone 7 plus that restart randomly here is the panic log i write below,i already did these solution:
-Changing the charging flex
-Changing the power flex
-Changing the battery flex
but nothing solved.any idea?
panic(cpu 1 caller 0xfffffff024e77f58): userspace watchdog timeout: no successful checkins from logd in 180 seconds
service returned not alive with context : unresponsive dispatch queue(s): com.apple.firehose.drain-mem, com.apple.firehose.io-wl
service: backboardd, total successful checkins since load (7830 seconds ago): 784, last successful checkin: 0 seconds ago
service: SpringBoard, total successful checkins since load (7827 seconds ago): 783, last successful checkin: 0 seconds ago
service: mediaserverd, total successful checkins since load (7830 seconds ago): 783, last successful checkin: 0 seconds ago
service: logd, total successful checkins since load (7830 seconds ago): 766, last successful checkin: 180 seconds ago
service: thermalmonitord, total successful checkins since load (7830 seconds ago): 783, last successful checkin: 0 seconds ago
service: runningboardd, total successful checkins since load (7830 seconds ago): 784, last successful checkin: 0 seconds ago
service: wifid, total successful checkins since load (7830 seconds ago): 784, last successful checkin: 0 s
Debugger message: panic
Memory ID: 0x6
OS release type: User
OS version: 19H370
Kernel version: Darwin Kernel Version 21.6.0: Sun Oct 15 00:18:06 PDT 2023; root:xnu-8020.241.42~8/RELEASE_ARM64_T8010
KernelCache UUID: CD36CE0B0356F65AFE5A8841F99CA9D2
Kernel UUID: D986A786-4953-350E-97CF-C0FCFF85FFCF
iBoot version: iBoot-7459.140.15
secure boot?: YES
Paniclog version: 13
Kernel slide: 0x000000001e20c000
Kernel text base: 0xfffffff025210000
mach_absolute_time: 0x2bedb1138e
Epoch Time: sec usec
Boot : 0x656693fb 0x000bf959
Sleep : 0x00000000 0x00000000
Wake : 0x00000000 0x00000000
Calendar: 0x6566b2a1 0x000b3cc7
Zone info:
Zone map: 0xffffffe000404000 - 0xffffffe600404000
. VM : 0xffffffe000404000 - 0xffffffe0e6a68000
. RO : 0xffffffe0e6a68000 - 0xffffffe133734000
. GEN0 : 0xffffffe133734000 - 0xffffffe219d98000
. GEN1 : 0xffffffe219d98000 - 0xffffffe3003fc000
. GEN2 : 0xffffffe3003fc000 - 0xffffffe3e6a64000
. GEN3 : 0xffffffe3e6a64000 - 0xffffffe4cd0cc000
. DATA : 0xffffffe4cd0cc000 - 0xffffffe600404000
Metadata: 0xffffffe797050000 - 0xffffffe798850000
Bitmaps : 0xffffffe798850000 - 0xffffffe799954000
CORE 0: PC=0xfffffff0258ebab4, LR=0xfffffff025977c10, FP=0xffffffe790c8a7f0
CORE 1 is the one that panicked. Check the full backtrace for details.
Compressor Info: 25% of compressed pages limit (OK) and 9% of segments limit (OK) with 0 swapfiles and OK swap space
Total cpu_usage: 59535582
Thread task pri cpu_usage
0xffffffe4cc5d4e10 watchdogd 97 0
0xffffffe4cc2cf138 deleted_helper 46 1658018
0xffffffe4cc66e328 mediaserverd 37 0
0xffffffe4cc220708 wifid 37 185
0xffffffe4cc378000 mediaserverd 37 3033
Panicked task 0xffffffe3e617b888: 216 pages, 4 threads: pid 57: watchdogd
Panicked thread: 0xffffffe4cc5d4e10, backtrace: 0xffffffe790d4b200, tid: 1453
lr: 0xfffffff0253d1ea0 fp: 0xffffffe790d4b240
lr: 0xfffffff0253d1c28 fp: 0xffffffe790d4b2b0
lr: 0xfffffff0254f1324 fp: 0xffffffe790d4b320
lr: 0xfffffff0254f02c8 fp: 0xffffffe790d4b3d0
lr: 0xfffffff0253955fc fp: 0xffffffe790d4b3e0
lr: 0xfffffff0253d1944 fp: 0xffffffe790d4b770
lr: 0xfffffff0253d1944 fp: 0xffffffe790d4b7d0
lr: 0xfffffff025a13000 fp: 0xffffffe790d4b7f0
lr: 0xfffffff024e77f58 fp: 0xffffffe790d4b810
lr: 0xfffffff024e7791c fp: 0xffffffe790d4b830
lr: 0xfffffff024e76cac fp: 0xffffffe790d4b950
lr: 0xfffffff0259a975c fp: 0xffffffe790d4baf0
lr: 0xfffffff0254bee40 fp: 0xffffffe790d4bc10
lr: 0xfffffff0253d7528 fp: 0xffffffe790d4bca0
lr: 0xfffffff0253b0444 fp: 0xffffffe790d4bd00
lr: 0xfffffff0253c5cd8 fp: 0xffffffe790d4bd90
lr: 0xfffffff0254e6854 fp: 0xffffffe790d4be60
lr: 0xfffffff0254f0760 fp: 0xffffffe790d4bf10
lr: 0xfffffff0253955fc fp: 0xffffffe790d4bf20
Score 1
Add a comment
The reason the three flex replacements changed nothing is in the first line: "no successful checkins from logd", with unresponsive queues com.apple.firehose.drain-mem and com.apple.firehose.io-wl. That's the logging service failing to answer the watchdog. No sensor is listed as missing, so this log doesn't point at the charging flex, the power flex or the battery.
iFixit's kernel panics wiki treats this type of check-in failure as a software-side problem. What has worked in a similar thread (SE 2020, same logd panic): restore through Recovery Mode and set the phone up as new, without restoring the backup, then observe for a day. Putting the full backup back can bring the restarts back with it.
If it still happens on a clean install with nothing restored, a fresh log from that clean state would be worth posting.
I maintain a sourced reference for panic-full codes; your thread is one of the cases cited on the logd page: https://checkpanicfull.com/panic-codes/w...
Add a comment
Based on the panic log, this appears to be a userspace watchdog timeout, specifically because logd stopped responding for 180 seconds.
The following are possible causes worth investigating:
  1. iOS software issue: Corrupted system files or an issue with the logging service.
  2. NAND/storage issue: Storage-related I/O problems may cause system services to become unresponsive.
  3. Logic board issue: A board-level fault could cause intermittent system hangs.
  4. Power management issue: Unstable power delivery may contribute to unexpected restarts.
  5. Peripheral hardware issue: A faulty connected component could potentially cause system instability.
Already replaced:
  • Charging flex
  • Power flex
  • Battery flex
Suggested troubleshooting:
  • Check battery health and available storage.
  • Compare multiple panic logs to identify recurring errors.
  • Test with a clean iOS installation after backing up data.
  • If the issue persists, perform professional logic-board diagnostics, particularly storage and power-related checks.
Question: Has anyone experienced this exact logd watchdog timeout on an iPhone 7 Plus running iOS 15.8.x? Which component or fault ultimately resolved the issue?
Any suggestions or repair experiences would be appreciated.
Add a comment
Add your answer
Mohamad Amin will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 35
All Time: 184
