The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
My phone always restart
my phone age was 2 years, and now always restart every time
how it be and how to fix it?
Score 1
Add a comment
1 Answer
@rahmanf could be a software issue. Try a reset of your software. Remember to make sure that all of your files are backed up etc. Also, check if this happens in safe mode as well or if it stays on. To get into safe mode use this site. If none of that helps/works, I would start by replacing the battery and making sure that your charging port works, once you replace the battery.
Add a comment
Add your answer
rahman f will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 533
