The Sony KDL-50W800C TV is a model with a screen diagonal of 127 cm, a screen resolution of 1920 x 1080 pixels, an aspect ratio of 16:9, 4 HDMI ports. 2 USB ports to connect an external hard drive. Ethernet port to connect to the internet via cable, internet connection via Wi-Fi, the Android operating system. Release date: 2015-07-02.
TV late starte. Give some help
TV late start and initiate screen not seen.
Add a comment
1 Answer
@radheshyam42855 "TV late start and initiate screen not seen." clarify this by giving us more history. LAte stat cold mean it takes some time to turn on. That could be an issue with the power board or the main board. So could be the no picture situation.
First, let us know what model your TV is. You picked the Sony KDL50W800C but we need to make sure. After that, unplug the TV and remove the back cover. Now take a look at the individual boards. Check for missing, charred looking components or burned traces. Check the heatsinks on the power board. I would suspect some MOSFET (as well as bad capacitors) being the cause for that. Post some good pictures of all of your boards with your Question, that way we can see what you see.
Adding images to an existing question
Add a comment
Add your answer
Radheshyam Aluminium will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 141
