Repair and disassembly information for Sony WH-1000XM4 wireless noise-cancelling over-ear headphones.
No sound from the left side.
Hello, I bought Sony WH-1000XM4 headphones in unknown condition. It turned out that the right side, the speaker and the touch panel were fully functional. On the left side, the buttons, NFC and indicator light work. The only biggest problem is that there's no sound from the left speaker. I tried to connect to the computer via aux and again, sound could only be heard from the right side. What could be causing this problem? I would be very grateful for your answer.
Add a comment
Hi,
I've had the same thing happen to my headphones. What I did was I wiggled the left earpiece around until the right sound turned on; It would only turn on if it was placed in a specific way so every time I use them i need to wiggle it. If you want to fix it permanently, you could try opening the left ear cup and checking if anything is disconnected, because that is usually the problem. Hope I helped!
5 Comments:
I opened it and checked if anything is disconnected before that and no, everything seems to be alright.
by
Im not sure then. Sorry.
by
I had this issue previously. If the swivel on the affected headphone is damaged in such a way that makes it possible to bet flipped backwards accidentally, it is possible that the headphone did a 360 without you noticing. This caused mine to become unreliable. If you flip them back to where they correctly work and then fix the swivel following the guide below, it should resolve the issue.
https://www.ifixit.com/GuideSony+WH-1000...
by
Thank you so much flumpledorf for the comment it turns out you were right my swivel was broken and all I needed to do was flip the headphones 360 and it fixed it
by
Guys I just fixed the swivel on the left hand side of the earphones and the sound on the left hand side works fine but for some reason the right side stopped working and I did not touch or remove the right side during the fixing of the swivel but I don’t know why no sound is coming from the right hand side this is the link to the video below please if somebody could help or explain the problem that would really help it only started once I fixed the swivel.
https://youtu.be/OtD5Cwn24GE?si=44_vGvsw...
by
Add a comment
try diffrent songs or sound tracks and see if there is a change.
Add a comment
Add your answer
thezoneofcum will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 141
All Time: 3,684
