Up to 20% off select tools
The EvoFox Fireblade Gaming Keyboard comes standard with the Windows Lock Key,12 Multimedia Keys and USB Plug N’ Play and it's Rainbow Backlighting with Breathing Effects makes this Keyboard always visible and always looking good. Built for Gaming - Proven in battle with 10 Million Keystrokes a Spill Resistant design, 1.5m Long Braided Cable with Magnetic Ring for precise data transmission.
Some Keys Not Working
(Sorry my english is not good)Some of The Keys are not working Properly after cleaning The Keyboard It happened while i was playing some games it eventually stopped working
Score 5
Add a comment
Most Helpful Answer
Depends on what switches you have. If the switches let light through to work, then something might be blocking it, If they arent then something else might be wrong. I would suggest taking it apart if you have some tools (screw drivers). Look to see if anything is disconnected, if its not then take the PCB and switches out and then put them back together. That should work but it's not guaranteed; If it doesn't then you should just replace the keyboard. I hope I was helpful!
Score 2
1 Comment:
I had the same problem so I took it apart. The wires going to the RGB lights had broken, which I might be able to solder. But now I cannot put it back together, even if I try to put it back together somehow it refuses to work at all. I really need a guide to put it back
by Share
Add a comment
tombol yang tidak bisa digunakan tombol spasi,g,h,pgup,tanda pettik dan esc
Add a comment
Add your answer
WazeNot TheBushido will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 74
All Time: 1,424
