The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
Passenger side power window will not work with either button
Passenger side power window will not go up or down.. I suspect it's I don't know where to find it. Any help would be appreciated
Update (11/11/23)
That should have said. I suspect it's a relay but don't know where to look for it
Score 1
Add a comment
1 Answer
Chosen Solution
@jimkern the relay is located in the fuse box to the left of the steering column. Relay 4 is the One-Touch down relay and #5 is the Delay relay.
Only issue with that is, that there is one relay for all the windows.
That makes it unlikely that this is the issue for your F-150 since it is only the one window that does not work. I would check the single switch for the particular window as well as the individual motor. Use something like the Power WIndow section Power Windows from the SM for the 1997-2004 Ford F-150 series to check it.
Score 1
1 Comment:
Thank you very much for your detailed response. A mistakenly thought since both switches did not work it had to be a relay, assuming that each window had its own relay. I'm sure your answer save me some time. I'll start at the switches and work my way back. Again thank you for your reply
by
Add a comment
Add your answer
Jim Kern will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 40
All Time: 711
