Repair and disassembly information for Google's Pixel 6 smartphone, released in October 2021. Identified by model number GB7N6 and G9S9B16.
Display does not respond to touch
Phone was dropped, then the touchscreen became intermittently non-responsive. Applying pressure to the sides of the device or providing some flex would get touch functionality to restore for a while. Eventually even this stopped working and the touch functionality stopped working entirely although the display itself is still perfect.
I figured this must be a screen issue though I dont understand why only touch would fail and not display; so I ordered a replacement screen and hooked it up to test but again have the same issue, display works perfect with no touch input being accepted. I inspected the connector/board for the display and don't see anything wrong (although I dont have magnification). I cleaned the board side of the connector with 90% IPA though it made no difference.
Anyone have an idea of what to look for? I understand I will most likely need a new phone at this point but I'm still interested in what went wrong.
Score 2
Add a comment
1 Answer
Have you rebooted the phone with the new screen attached? I had one one that needed it to be done twice before the screen was accepted and the touch then worked. You may even have to reset it if just a reboot doesn't work.
3 Comments:
Did old screen work? I have the same issue touch is not working even though there is no crack
by
hi i have the same issue there was no cracks whatsoever is there anything u can do about it? or how did u fix it?
by
My Pixel 6 Pro took 5 reboots before it finally recognized the touchscreen and started to work. I still had to run the google tool to enable the fingerprint detector, but that was rather trivial.
by
Add a comment
Add your answer
Mike Meller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 61
All Time: 2,292
