Not all the bulbs light up
I have 423 addressable LEDS that I soldered (first time) together. I turned it on and everything worked. I then put the strip into the location I wanted and now only the first 50sih work. I have looked at all my solder location and everything seems fine. I do have a multimeter to help figure out where my problem is, but I don't know which function/how to use it. Any help will be amazing.
2 Comments
@mitchellb75424 How are you powering the LEDs? If using an external power supply/LED Driver, what are its specifications?
by
The LEDS are powered via external source, 5V 2A. I know that since I had to re-solder some wires, I am sure that is the issue but as I don't know which ones are bad, I was hoping there was a way to test via multimeter.
by
Add a comment
1 Answer
Most Helpful Answer
@mitchellb75424 The first thing I would do would be to check the voltage on the first LED. You can do this by putting the multimeter probes in the common socket (black probe) and V etc. socket (red probe). Set your multimeter to 20 VDC (V with a straight solid line and a straight dotted line) or just VDC (for an auto-ranging meter). Plug in the light strip and measure across the two solder points of the first LED that doesn't light up. What voltage do you get?
Score 1
2 Comments:
I got 4.89 on the furthest strip.
by
@mitchellb75424 Can you upload a picture of the LED strip? Adding images to an existing question
by
Add a comment
Add your answer
Mitchell B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 467
