Device repair information for the first generation of V-Moda Crossfade Wireless headphones.
Broken headphone slider/adjuster
The slider on one side of the headphones is loose and doesn't lock. Upon further inspection, it appears a small bent brass component is out of place. Is there any way to fix this?
Add a comment
1 Answer
Figuring out how to take it apart to get at it is the first problem.
2nd problem would be figuring out how to re-bend the part, if that is all it is.
3nd problem is figuring out how to put it back together.
If there is a broken plastic part in it, you will need a CAD program and a 3D printer to reproduce it, assuming it is big enough to print and isn't broken too bad.
Add a comment
Add your answer
The “E.D.Z.123” will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 429
