The Xiaomi Redmi Note 11 Pro is a mid-range smartphone by Xiaomi released January 2022. It has a 6.67" Super AMOLED display, a 108 MP main camera, a side-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Mediatek Helio G96.
Water damaged speaker and microphone
Hi I had dropped my phone in water then I turned it off tried to dry it after that i left it for half of the day
The problem is all the sensors doesn't work at all and the sound turns off every 4 seconds then works again by itself even if I used headphones so as the mic sometimes all of them stop working until I restart it
Is there anything I can do except sending it to a repair center
Add a comment
1 Answer
Hi @n0name
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Xiaomi Redmi Note 11 Pro guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Add a comment
Add your answer
N0 Name will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 26
All Time: 647
