Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
printer paper does not load, please help
paper does not loaded while printing so i used back side but that back side to print is only accept 1 paper at time so its exhausting , the normal blank paper load does not work so i use that option , how can i fix this? so i can print 10+ times arow and not once a time using back-side of printer option . please let me know as soon as possible
Score 1
Add a comment
1 Answer
Chosen Solution
@karimhalawi this is what you want to check on your printer first
After that, it gets kind of tricky and way to much to write on here. I suggest you get the SM Brother MFC J3520 And Others and use the steps on page 88 to determine what is going on with your printer.
1 Comment:
thank you sir, i will try out and let u know
by
Add a comment
Add your answer
karim halawi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 239
