The Lenovo IdeaPad 1-11lGL05 is a laptop made by Lenovo. This page contains repair and service information related to the Lenovo IdeaPad 1-11lGL05.
How can I stop my power light flashing?
How can I stop my power light flashing??
2 Comments:
What have you tried?
by
I think it should blink untill the battery is fully charged.
by
Add a comment
@bettychow you need to let us know if it is blinking fast or slow. Fast blinking is usually caused by a battery that is below 20% while a slow blinking light means it is in sleep mode. For that try resetting your Lenovo by unplugging it from the power source, removing the battery (if possible), and then holding the power button for 30 seconds. Any of these can also be indicative off a hardware problem, like a bad battery.
To work on your Lenovo, download the service manual from here It will at ;least help you to work on it. I would start with replacing the battery and checking the DC in jack as well as the power lines to the charging circuit.
Add a comment
With laptop closed and white power button flashing hold power on button for 7 seconds at same time lift open laptop a little now keyboard lights off and close lid .
Now power button stopped flashing and just check after couple of minutes it really has SOLVED THE PROBLEM.
Note please check power button is not flashing each time you SHUT DOWN if flashing you now NOW HOW TO TURN OFF .
APPRECIATE YOUR FÈED BACK 🥳👍
Update (10/09/24)
It really solves the problem excellent information top NURD
Add a comment
Add your answer
Betty Chow will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 40
All Time: 2,702
