The Xiaomi Redmi Note 10 Pro is a mid-range smartphone by Xiaomi released March 2021. It has a 6.67" AMOLED display, a 108 MP main camera, a side-mounted fingerprint sensor, a 5020 mAh battery, and runs on a Snapdragon 732G.
Why my fingerprint does not work
Score 3
7 Comments:
Not show fingerprint option on setting and try all options are setting does not show and work fingerprint option
by
How could i use fingerfrint senson
by
Why my fingerfrint does not work
by
by
Show 2 more comments
Add a comment
@bikashsah I suggest that you start by restarting your phone. Next, you want to check if your phone's software is outdated. Go to "Settings" > "Software update" and check for any available updates. Then you have to consider that Xiaomi may have turned the fingerprint sensor software off. Xiaomi has had a lot of bugs with their fingerprint sensor and software. Of course, then there is also the possibility of this being a hardware issue. If your sensor has failed, your software will most likely not find it.
Since iFixit does not yet have a guide for this, use something like this guide to replace it. A new sensor flex is readily available at many online stores. Use a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Add a comment
Try updating your fingerprint extension service. The update is in this site....
https://www.apkmirror.com/apk/xiaomi-inc...
Add a comment
Add your answer
Bikash Sah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 51
All Time: 7,430
